Scale length and hand size http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=22545 |
Author: | George Thomas [ Thu May 28, 2009 10:49 am ] |
Post subject: | Scale length and hand size |
Hi: I have been following an interesting thread on another forum (not a member due to infrequent posts) and wanted to see what folks here thought about a related question. For classical guitars would you reduce the size of the plantilla if planning on using a 630mm scale length? The other thread had to do with slightly smaller guitars and got into a discussion of hand size and the optimal scale for smaller hands. There was another discussion of hand size and measuring it a while back and referenced an author named Alicia, last name forgotten. I have not been able to find in the archives here or on the other forum. Does anyone remember this? Thanks. |
Author: | Ricardo [ Thu May 28, 2009 12:03 pm ] |
Post subject: | Re: Scale length and hand size |
George I'm in the process of building my second guitar with 24.9 scale. I find that with my small hands its much easier to play. In both cases the mods were minimal - shorter neck and I just moved up the bridge a bit. On the steel string the X bracing was such that moving the bridge closer to the sound hole had minimal impact. On the CG no mods required to fan bracing. |
Author: | Alan Carruth [ Thu May 28, 2009 2:36 pm ] |
That prior thread about hand size probably reffered to Alicia Kopfstein-Penk, who wrote a book called 'The Healthy Guitar' about this subject. You can get the book from her: c.kopfstein@verizon.net |
Author: | George Thomas [ Thu May 28, 2009 6:33 pm ] |
Alan: Thanks for the email address. I will give a try. By having her full name I was also able to find another email address for her (akp@american.edu). Ricardo: There does not seem to be any structural reason to move up the bridge and make the necessary bracing adjustments to accomodate a shorter scale. There might be an aesthetic one. We will see when I give it a try. Thanks. |
